Mobile Requests - How to change the Request state?
To change the state of a Request, follow these steps:
  1. On the Dashboard, select the option "Requests" or select the option "Requests" on the menu. On the Requests list, select the request you wish to change;
  2. On the request view, select the state.
  3. The list of possible states to change is presented.
  4. Select the state which you want to change the request to;
When changing states, you must consider the following:
  1. To undo the changes performed, before synchronizing, click on the arrow at the right of the state.
  2. If the state transition performed needs to be justified, a pop-up is presented;
  3. If the state selected is a state with no changes possible, you will no longer be able to access the state list.
State transition justification - If the state transition performed needs to be justified, a pop-up is presented. On the justification dialog box, there are the following fields:
  1. Justification – This is automatically filled in if there is a default justification;
  2. Justification type – This is automatically filled in if there is a default justification type associated to the justification selected. This field is only available after selecting the change justification;
  3. Notes – free text;
All fields can be filled in, but one of the fields is mandatory: Justification or Notes
    • Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
      On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: Details tab - viewing request/workflow state transitions. Remarks tab - changing remarks. Attachments tab - adding attachments. To ...
      On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
    • Mobile Requests - Error handling
      On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
    • Request Mobile – How to explore the requests?
       The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. ​Dashboard – allows the ...
    • Mobile Requests – How to explore the requests?
      The Requests can be viewed using the following options: ​ i.Requests List – allows the Requester to view the state Requests you created, as well as view the Requests created on the device and that have not been synchronized yet. ii.Dashboard – allows ...
