Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
On the Requests that have
already been synchronized to Web CMMS, it is only possible to perform the
following changes:
- Details tab - viewing request/workflow state
transitions.
- Remarks tab - changing remarks.
- Attachments tab - adding attachments.
To change data in a Request,
follow these steps:
- On the Dashboard, select the option
"Requests" or select the option "Requests" on the
menu.
- On the Requests list, select the tab Requests, and
the request list is presented.
- Edit the request and change the fields that can be
changed.
- Press the "Checkmark" icon on the upper right
corner.
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
Mobile Requests -How to change a Request that has already been synchronized to Web CMMS?
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: Details tab - change the request state. Remarks tab - change the remarks, given that the request state allows it. Attachments tab - ...
Mobile Requests -How to change a Request that hasn't been synchronized to Web CMMS?
You can only change the Requests that have not been synchronized yet in draft. To change data in a work order, follow these steps: On the Dashboard, select the option "Requests" or select the option "Requests" on the menu. From the list of Requests, ...
Mobile - How to change a work order that was not yet synchronized to the web cmms?
You can only change work orders that have not been synchronized yet in draft. To change the data of a work order, you must follow these steps: On the dashboard, select "Report Work" or on the menu select the option "My Work" On the Work orders, press ...
Mobile Requests - Error handling
On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
