Mobile Requests -How to change a Request that has already been synchronized to Web CMMS?
On the Requests that have already been
synchronized to Web CMMS, it is only possible to perform the following changes:- Details tab - change the request state.
- Remarks tab - change the remarks, given that the request state allows
it.
- Attachments tab - adding attachments.
To change data in a Request, follow these
steps:- On the Dashboard
select the option "Requests" or select the option "Requests"
on the menu.
- On the Requests
list, select the tab Requests, and the request list is presented.
- Edit
the request and change the fields that can be changed.
- To save the
changes, select the icon "Checkmark" on the upper right
corner.
Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: Details tab - viewing request/workflow state transitions. Remarks tab - changing remarks. Attachments tab - adding attachments. To ...
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
Mobile Requests -How to change a Request that hasn't been synchronized to Web CMMS?
You can only change the Requests that have not been synchronized yet in draft. To change data in a work order, follow these steps: On the Dashboard, select the option "Requests" or select the option "Requests" on the menu. From the list of Requests, ...
Mobile - How to change a work order that was not yet synchronized to the web cmms?
You can only change work orders that have not been synchronized yet in draft. To change the data of a work order, you must follow these steps: On the dashboard, select "Report Work" or on the menu select the option "My Work" On the Work orders, press ...
Mobile Requests - Error handling
On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
