Mobile - How to view the attachments for the work order and their assets
To view the attachments of a work order, you must enter the desired work order and press the attachment tab on the lower corner.
The attachments will be presented in 2 areas:
  •      Work Order - Attachments regarding the work order;
  •      Assets - Asset attachments for the work order.
To view the attachment information, click the attachment and the file will be downloaded.
If there are no attachments in one of those areas, that area will be hidden.
    • Mobile - How do I see the Work Order information?
      To see information on a work order (WO), you have to go to the WO's list, select the desired WO and click on the information icon in the top right-hand corner. The information displayed relates to the selected WO, where the corresponding information ...
    • Mobile - How to record and view follow-ups?
      To access the Work Order follow-ups, follow these steps: 1.     Access Menu | My Work 2.     On the work order list, select the work order you wish to follow-up on; 3.     Access the Follow-up tab on the lower part of the screen. 4.     On the ...
    • Mobile - How do I create a Work Order?
      The Work Order (WO) is the entity which represents the maintenance work to be performed for an asset or location. To create a work order, follow these steps: On the menu, select the option "New Work Order"; The work order creation window is ...
    • Mobile - How to see down time associated to a work order?
      When a work order is in a stopped operating state, the system automatically records a down time for the asset or location associated to the work order. To change WO downtime reports, access the work orders list (Menu | Report Work) On the work orders ...
    • Mobile - How to explore work orders?
      It is very important for technicians to be able to quickly view the work that they must perform. You can check the work that needs to be done through the following options: Technician dashboard – allows technicians to immediately know the number of ...
