Mobile – How to set up the Valuekeep Requester CMMS?
The Valuekeep CMMS can be performed using
the login screen or using the application menu (Menu → Configurations).
The configurations are defined in the
following areas:
Language – by default, the app uses the language selected in
the operating system If you wish to change the language, after selecting
the desired language, you must restart the app.
Profile information - on this screen you can find profile
information for the user currently logged in, as well as application and
database version data.
Push Notifications
– to receive
push notifications, the technician needs to consent to the collection.
Notify when finished
Integrated Access
- allows to
perform the login inside the app, with the exception of logins in google
accounts.
Pin -
for an improved data
security, the technician can create a PIN to access the application, as
well as changing the PIN previously defined. The pin must be a number
with 4 to 6 digits.
If the user has a defined PIN, the PIN is requested
when:
i.
Entering the
application and there is a previously selected subscription;
ii.
Accessing
the selection of the subscription;
iii.
Accessing
the application configurations;
iv.
Removing
the PIN use;
Activating/Deactivating/Changing PIN.
i.
To activate
the safety option with PIN, click on the PIN option, define the desired PIN,
and then confirm it.
ii.
To
deactivate the PIN, click the PIN option and enter the current PIN.
iii.
To change
the PIN, click the option Change PIN and enter the current PIN and the new one,
The PIN is only requested after opening the
app or changing user, except when trying to change or remove the PIN.
The notifications are generated and
assigned to the app installed. If there is more than one user logged-in on the
same device, you can receive the notification destined for another user.
The notification is sent to the last device
used by the user.
How to access the Valuekeep Requester CMMS mobile app?
To access the Valuekeep Requester CMMS, before entering the app, you must accept the request you've been sent. Roles supported on the Valuekeep Requester CMMS app: Root - Administrator Requester - Requester RequestsManager - Requests Manager If you ...
Mobile – How to set up the Valuekeep CMMS?
i. The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
How to access the Valuekeep Technician CMMS mobile app?
To access the Valuekeep Technician CMMS, before entering the app, you must accept the request previously sent. Roles supported on the Valuekeep Technician CMMS app: Root - Administrator Technician - Technician WorkManager - Work Manager
Mobile - How to do Valuekeep CMMS's configuration?
The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
Mobile - How to change the user on the Valuekeep CMMS app?
The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
