Mobile – How to set up the Valuekeep CMMS?
i.
The
Valuekeep CMMS configuration can be performed using the login screen or using
the application menu (Menu → Configurations).
The configurations are defined in the
following areas:
Language – by default, the app uses the language
selected in the operating system If you wish to change the language,
after selecting the desired language, you must restart the app.
Profile information – on this screen you can find profile
information for the user currently logged in, as well as application and
database version data.
Geolocation - to perform the GPS coordinates collection, the
technician needs to consent to the collection.
Push Notifications - to receive push notifications, the
Notify when finished
Signature - if the technician wishes to get the customer and
technician signature on the report, he must activate the signature
option.
Preview Print - if the technician wishes to view the work
order report, before printing it, he must activate this option.
Integrated Access - allows to perform the login inside the
app, with the exception of logins in google accounts.
Pin - for an improved data security, the technician can
create a PIN to access the application, as well as changing the PIN
previously defined. The pin must be a number with 4 to 6 digits.
If the user has a defined PIN, the PIN is
requested when:
vi.
Entering
the application and there is a previously selected subscription;
vii.
Accessing
the selection of the subscription;
viii.
Accessing
the application configurations;
ix.
Removing
the PIN use;
Activating/Deactivating/Changing PIN.
x.
To activate
the safety option with PIN, click on the PIN option, define the desired PIN,
and then confirm it.
xi.
To
deactivate the PIN, click the PIN option and enter the current PIN.
xii.
To change
the PIN, click the option Change PIN and enter the current PIN and the new one,
The PIN is only requested after opening the
app or changing user, except when trying to change or remove the PIN.
The notifications are generated and assigned
to the app installed. If there is more than one user logged-in on the same
device, you can receive the notification destined for another user.
Mobile – How to set up the Valuekeep Requester CMMS?
The Valuekeep CMMS can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the language selected in ...
Mobile - How to do Valuekeep CMMS's configuration?
The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
Mobile - How to change the user on the Valuekeep CMMS app?
The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
Mobile - How to select the subscription and company to start working with Valuekeep CMMS?
When accessing the Valuekeep CMMS after logging in, you need to identify which subscription and company you are going to work with. To select the desired subscription and company for the current user, click “Enter” on the initial screen: Select the ...
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
