Mobile - How to see down time associated to a work order?
When a work order is in a stopped operating state, the system automatically records a down time for the asset or location associated to the work order.
To change WO downtime reports, access the work orders list (Menu | Report Work)
  1. On the work orders list, select the work order you wish to see the downtime reports;
  2. On the work order options (3 dots icon) click on Report Downtime;
  3. A list with the downtime reports for assets associated to the selected work order;
To edit the reports, select the desired field and select the desired date. After the desired changes, in order to save select the checkmark in the upper right corner.
On the downtime report, you must consider:
  1. The downtime report is performed for the asset associated to the work order and their child assets;
  2. When the work order is for a route, the downtime affects all the elements of the route.
    • Mobile - How do I see the Work Order information?
      To see information on a work order (WO), you have to go to the WO's list, select the desired WO and click on the information icon in the top right-hand corner. The information displayed relates to the selected WO, where the corresponding information ...
    • Mobile - How to view the attachments for the work order and their assets
      To view the attachments of a work order, you must enter the desired work order and press the attachment tab on the lower corner. The attachments will be presented in 2 areas: Work Order - Attachments regarding the work order; Assets - Asset ...
    • Mobile - How do I create a Work Order?
      The Work Order (WO) is the entity which represents the maintenance work to be performed for an asset or location. To create a work order, follow these steps: On the menu, select the option "New Work Order"; The work order creation window is ...
    • Mobile - How do I print a work order report?
      The technicians can print the work order report with or without the signature when ending or during the execution. To print a work order report, it is necessary to access the detail window of the workorder. The access to this detail is performed ...
    • Mobile - How to explore work orders?
      It is very important for technicians to be able to quickly view the work that they must perform. You can check the work that needs to be done through the following options: Technician dashboard – allows technicians to immediately know the number of ...
