Mobile - How to report consumptions from the requisition?
To report
consumptions from the requisition, follow these steps:
- Access Menu |
Report Work;
- On the work
order list, select the work order you wish to report consumption;
- On the work
order options (3 dots icon), click Consumption;
- The list of work
order consumption reports will be displayed;
- To create a
consumption report, click the icon (+);
- On the
consumption report form, fill in the required fields, identified with (*)
and add the part consumptions, by clicking the icon (+);
- To add parts
to a requisition, click the option "Requisitions";
- The list of
requisition parts associated to a work order is presented;
- You can
select each element of the list or select all;
- Click the
checkmark to save the consumption report.
It
is only possible to create reports if the work order state allows to record
work.
The
quantity of requisition parts on the list of requisition parts associated to
the work order is always the same as the original quantity. The quantity is
validated when synchronizing.
Mobile - How do I report, change or delete consumptions?
To report consumptions, follow these steps: Access Menu | Report Work; On the work orders (WO) list, select the WO for which you want to consult/record consumptions; On the work order options (3 dots icon), click on Consumption; The list of ...
Mobile - How to report consumptions from the requisition? To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order ...
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
How to create custom mobile reports?
If you wish to create a custom mobile report, you must use our base report. Click the attachment to download the base mobile report.
