Mobile - How do I report task verifications?
To access the tasks that require verification in a work order (WO), follow these steps:
- Access the Menu | Report Work;
On the WOs list, select the work order for which you want to
consult the tasks;
- Access the Tasks tab;
If the WO is for an asset (location, equipment or tool), a list of all the WO tasks is presented. If it is for a route,
the list of tasks for one of the assets/locations of the route is
displayed. You can choose other assets/locations by first selecting the
asset type and then the asset.
The lists contain synchronized verifications, verifications pending
synchronization and verifications whose synchronization failed.
Verify a task
To verify a task,
follow these steps:
- Go to the WO task
list;
- Select the 3 dots
icon;
- In the
verification form, fill in the verification type and remarks.
- Click on Save.
It is possible to apply a task verification to all tasks in a WO configured with the same
verification type. To do so, in the
verification form you must activate the Apply to all? field. You will be
asked whether you want to apply it to all the route's assets and if so, if so,
answer:
- Yes: it applies the
verification to all the route's assets, with the same type of
verification being edited at the time of the verification;
- No: it applies the
verification to all tasks, but only to the selected route asset.
It is only possible to verify tasks if the WO status allows he task verification.
Delete Task Verification
For this operation to
succeed, you can only select non-synchronized tasks. To delete task
verifications, you must go to the WO's task list, click on the 3 dots icon and,
in the form, remove the verification.
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
Mobile - How do I print a work order report?
The technicians can print the work order report with or without the signature when ending or during the execution. To print a work order report, it is necessary to access the detail window of the workorder. The access to this detail is performed ...
How to create custom mobile reports?
If you wish to create a custom mobile report, you must use our base report. Click the attachment to download the base mobile report.
Mobile - How to report consumptions from the requisition?
Mobile - How to report consumptions from the requisition? To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order ...
