Mobile - How to report labor using the timer?
When a work order is on a state that allows to report work, when accessing the WO file, the option “Timer” will be available on the work order view, on the right lower corner. To report labor using the timer, you must perform the following steps:
- Access the Menu | Report Work;
- On the work orders list, select the work order you wish to report the labor on;
- Click on the timer icon to start the labor time
On the labor report using the timer, you must consider that:
- When selecting that icon, a Timer is presented and it can be started and stopped at any time;
- When finishing the timer, a labor report dialog box will be presented with all fields previously filled in with the timer value
- If you leave the labor report created, all data created by the timer will be lost .
- It is possible to leave the Timer dialog and keep the Timer active;
- If you access a WO timer with another active timer, a message is triggered questioning if you wish to stop the active timer;
- If you say yes, a labor report dialog box will be presented will all the timer values previously filled in.
It is not possible to exit the active session (subscription/company) if there is an active timer.
Mobile - How do I report, change or delete labor?
To report labor, follow these steps: Access Menu | Report Work; On the work order list, select the WO you wish to view/record the labor; On the work order options (3 dots icon), click on Labor; The WO's labor records list is presented: Synchronized ...
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
Mobile - How do I change the status of the work orders?
In the state transition, you must consider that: to remove the transitions performed, before synchronizing, click on the arrow to the right of the status. If the statuses transition performed requires a justification, a dialog is displayed to insert ...
Mobile - How do I print a work order report?
The technicians can print the work order report with or without the signature when ending or during the execution. To print a work order report, it is necessary to access the detail window of the workorder. The access to this detail is performed ...
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
