Mobile - How to record/change/delete requisitions?
To create a
Requisition, follow these steps:
- Access the "Requisitions" option;
- The requisition list is presented:
- Synchronized reports - these only allow to view, you cannot
change them;
- New reports pending synchronization;
- Reports with a synchronization error.
Creating
a new Requisition
To create a new
Requisition, you must access the list of requisitions:
- Click the icon (+)
- On the requisition form, fill in the required fields, identified
with (*), add the parts, by clicking the icon (+) and the work orders on the
tab "Work Orders";
- You can select to record parts using the barcode or manually.
- On the part record form, fill in the required fields, identified
with (*);
- Click on the checkmark to save the parts;
- Click on the checkmark to save the Requisition;
To edit a
requisition, you must access the list of requisitions:
- On the requisition form, edit the desired fields;
- To edit the parts, click on the part options (3 dots icon) and
click Edit;
- On the part report form, edit the desired fields;
- Click the checkmark to save the part report.
- Click on the checkmark to save the Requisition.
It is not
possible to edit synchronized reports.
To delete a
- Click the report options you wish to delete (3 dots icon)
- Click Delete.
- To delete a part report, access the part list:
- Access the part edition dialog;
- Click the part report options you wish to delete (3 dots icon)
and click Delete.
It is not
possible to delete synchronized reports.
To synchronize a
- Click the report options you wish to synchronize (3 dots icon);
- Click Synchronize.
To
synchronize one or several Requisitions simultaneously, click the
synchronization icon available on the Dashboard or on the Work Orders List.
Table of contents To create a Requisition, follow these steps: 1. Access the "Requisitions" option; 2. The requisition list is presented: 1. Synchronized reports - these only allow to view, you cannot change them; 2. New reports ...
Mobile - How to report/change or delete misc costs?
To report misc costs, you must perform these steps: Access Menu | Report Work; On the work order select the work order you wish to view/record the misc costs; On the work order options (3 dot icon) click on Misc Costs; A misc costs report list is ...
Mobile - How do I create, edit or delete failures?
The failures are always associated to work orders. You can access the failure report using the Menu | Report Work On the Work order list, select the work order failure you wish to view to see; On the work order options (3 dots icon) click on Failures ...
Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: Details tab - viewing request/workflow state transitions. Remarks tab - changing remarks. Attachments tab - adding attachments. To ...
Mobile - How to report consumptions from the requisition?
Mobile - How to report consumptions from the requisition? To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order ...
