Mobile - How to report/change or delete misc costs?
To report misc costs, you must perform these steps:
- Access Menu | Report Work;
- On the work order select the work order you wish to view/record the misc costs;
- On the work order options (3 dot icon) click on Misc Costs;
- A misc costs report list is presented for the work order :
- Synchronized reports - these only allow to view, you cannot change
- New reports pending synchronization;
- Reports with a synchronization error.
Synchronized reports only allow to view.
Create Misc Costs report
To create a misc costs report, access the misc costs report list:
- Click on the (+) icon
- On the misc costs report form, fill in the mandatory fields, identified with a (*)
- Click on the checkmark to save the report.
It is only possible to create reports if the WO state allows to record work.
Edit Misc Costs reports
To edit a Misc Costs report access the misc costs reports list:
- Click on the report options you wish to edit (3 dot icon)
- click Edit;
- On the misc costs report form, edit the fields you wish to change;
- Click the checkmark to save the report.
It is not possible to edit synchronized reports.
Delete Misc Costs report
To delete a misc costs report access the misc cost reports list:
- Click on the misc costs options you wish to delete (3 dot icon)
- click Delete.
It is not possible to delete synchronized reports.
Synchronize Misc Costs report
To synchronize a Misc Costs report, access the misc costs reports list:
- Click on the misc costs options you wish to synchronize (3 dot icon)
- click Synchronize.
To synchronize one or several misc costs reports simultaneously, click on the synchronization icon available on the dashboard or on the work order list.
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
Mobile - How to record/change/delete requisitions?
Table of contents To create a Requisition, follow these steps: 1. Access the "Requisitions" option; 2. The requisition list is presented: 1. Synchronized reports - these only allow to view, you cannot change them; 2. New reports ...
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
Mobile - How do I report, change or delete labor?
To report labor, follow these steps: Access Menu | Report Work; On the work order list, select the WO you wish to view/record the labor; On the work order options (3 dots icon), click on Labor; The WO's labor records list is presented: Synchronized ...
Mobile - How do I report, change or delete consumptions?
To report consumptions, follow these steps: Access Menu | Report Work; On the work orders (WO) list, select the WO for which you want to consult/record consumptions; On the work order options (3 dots icon), click on Consumption; The list of ...
