Mobile - How do I report, change or delete labor?
To report labor, follow these steps:
- Access Menu | Report Work;
- On the work order list, select the WO you wish to view/record the labor;
- On the work order options (3 dots icon), click on Labor;
- The WO's labor records list is presented:
- Synchronized records: you
can't change them, only see them;
- Records of the new
synchronization pendants;
- Records whose
synchronization failed.
Create Labor Record
It is only possible to create records if the WO status allows work recording.
To create a Labor record,
follow these steps:
- Go to the labor records
list;
- Click on the +
icon;
- Fill in the compulsory
fields;
- Save the record.
The hourly rate
is automatically selected according to what the employee has in their
backoffice file.
If the WO status is
configured to Start Timer, when the WO switches to that status, it
automatically starts the labor time. If it is configured as End Timer,
when the WO switches to that status, labor time finishes automatically.
Edit Labor record
edit labor records that have not been synchronized yet.
To edit a Labor record,
follow these steps:
- Go to the labor
records list;
- Click on the
options of the record you want to edit (3 dots icon);
- Click on Edit;
- Change the desired
information;
- Save the record.
Delete Labor reports
To delete a Labor record,
follow these steps:
- Go to the labor
records list;
- Click on the
options of the record you want to delete (3 dots icon)
- Click on Delete.
It is not possible to delete already synchronized records.
Synchronize Labor records
To synchronize a Labor record,
follow these steps:
list;
- Click on the
options of the record you want to synchronize (3 dots icon);
- Click on Synchronize. To
synchronize several Labor records at the same time, click on the
synchronization icon available on the dashboard or in the WOs' list.
Mobile - How to report/change or delete misc costs?
To report misc costs, you must perform these steps: Access Menu | Report Work; On the work order select the work order you wish to view/record the misc costs; On the work order options (3 dot icon) click on Misc Costs; A misc costs report list is ...
Mobile - How do I change the status of the work orders?
In the state transition, you must consider that: to remove the transitions performed, before synchronizing, click on the arrow to the right of the status. If the statuses transition performed requires a justification, a dialog is displayed to insert ...
Mobile - How to record/change/delete requisitions?
Table of contents To create a Requisition, follow these steps: 1. Access the "Requisitions" option; 2. The requisition list is presented: 1. Synchronized reports - these only allow to view, you cannot change them; 2. New reports ...
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
Mobile - How to report labor using the timer?
When a work order is on a state that allows to report work, when accessing the WO file, the option “Timer” will be available on the work order view, on the right lower corner. To report labor using the timer, you must perform the following steps: ...
