Mobile - How do I report, change or delete consumptions?
To report consumptions, follow these steps:
- Access Menu | Report Work;
On the work orders (WO) list, select the WO
for which you want
to consult/record consumptions;
- On the work order options (3 dots icon), click on Consumption;
- The list of consumption records for the work order is displayed, where you can consult the:
- synchronized records (you can only consult
them);
new
records pending synchronization;
records
whose synchronization
failed.
Create Consumption Record
To create a consumption
record, follow these steps:
- Go to the
consumptions log list;
- Click on the +
icon;
- In the consumption
record form, fill in the mandatory fields and add the parts consumption by
clicking on the + icon. You can choose to record your consumptions
through the barcode or manual recording;
- In the parts
consumption record form, fill in the mandatory fields;
Note: After selecting the part for consumption, you can only
select the warehouses without access restrictions and the warehouses to
which the user has access. Warehouses that have been configured with
access restrictions and whose permission has not been granted are not
available; - Save the
consumption record.
It is only possible to create records if the WO status allows work recording.
Edit Consumption Records
To edit a consumption
log, follow these step:
- Go to the
consumptions record list;
- Click on the +
icon;
record form, edit the desired fields;
- To edit a parts
consumption, click on the parts consumption options (3 dots icon) and then
on Edit;
- In the parts
consumption record form, change the desired fields;
- Save the parts
consumption record and then save the consumption record.
It is not possible to edit already synchronized records.
Delete Consumption Records
To delete a
consumption record, follow these steps:
- Go to the
consumption record list;
- Click on the
options of the record you want to delete (3 dots icon);
- Click on Delete;
- Go to the
consumptions record list and then edit the consumption record;
- Click on the
options of the parts consumption record you want to delete (3 dots icon) and
then, on Delete.
It is not possible to delete already synchronized records.
Synchronize Consumption Records
To synchronize a
Consumption record, simply go to the consumption records list, click on the
options for the record you want to synchronize (3 dots icon) and select the Synchronize
option.
To synchronize one
or more records at the same time, click on the synchronization icon
available on the dashboard or in the work orders list.
Mobile - How to report/change or delete misc costs?
To report misc costs, you must perform these steps: Access Menu | Report Work; On the work order select the work order you wish to view/record the misc costs; On the work order options (3 dot icon) click on Misc Costs; A misc costs report list is ...
Mobile - How to record/change/delete requisitions?
Table of contents To create a Requisition, follow these steps: 1. Access the "Requisitions" option; 2. The requisition list is presented: 1. Synchronized reports - these only allow to view, you cannot change them; 2. New reports ...
Mobile - How to report consumptions from the requisition?
Mobile - How to report consumptions from the requisition? To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order ...
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
Mobile - How do I report, change or delete labor?
To report labor, follow these steps: Access Menu | Report Work; On the work order list, select the WO you wish to view/record the labor; On the work order options (3 dots icon), click on Labor; The WO's labor records list is presented: Synchronized ...
