Mobile – How to explore the requisitions?
Requisitions can
be viewed using the following options:
- Requisitions - On the
main Dashboard screen, you can access the option "Requisitions",
where all requisitions created by the logged-in user are listed, ordered in
decreasing order of request date.
- Requisitions by
Work Order -
Access the option "Report Work", enter the Work Order and, on the
upper right corner, click on the 3 dots button ("..."), and the
option Requisitions will be presented. In that option, all Requisitions
associated to the selected Work Order will be presented.
Requisitions can be viewed using the following options: i.Requisitions - On the main Dashboard screen, you can access the option "Requisitions", where all requisitions created by the logged-in user are listed, ordered in decreasing order of request ...
Request Mobile – How to explore the requests?
The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. Dashboard – allows the ...
Mobile - How to record/change/delete requisitions?
Table of contents To create a Requisition, follow these steps: 1. Access the "Requisitions" option; 2. The requisition list is presented: 1. Synchronized reports - these only allow to view, you cannot change them; 2. New reports ...
Mobile - How to explore work orders?
It is very important for technicians to be able to quickly view the work that they must perform. You can check the work that needs to be done through the following options: Technician dashboard – allows technicians to immediately know the number of ...
Mobile - How to report consumptions from the requisition?
Mobile - How to report consumptions from the requisition? To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order ...
