Mobile - How to add the user account to the CMMS Valuekeep app?
After downloading the app, it is necessary to add the user account to the app, so that you can login. For that, follow these steps:
- When first accessing the application, on the initial screen, click the button “Add user”;
- If there are other accounts, on the initial screen click “Change user” and then the icon (+) on the right lower corner;
- Login on the presented “Identity” page.
You can only add user accounts when the device is connected to the internet
Mobile - How to change the user on the Valuekeep CMMS app?
The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
How to access the Valuekeep Requester CMMS mobile app?
To access the Valuekeep Requester CMMS, before entering the app, you must accept the request you've been sent. Roles supported on the Valuekeep Requester CMMS app: Root - Administrator Requester - Requester RequestsManager - Requests Manager If you ...
Mobile - How to do Valuekeep CMMS's configuration?
The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
How to access the Valuekeep Technician CMMS mobile app?
To access the Valuekeep Technician CMMS, before entering the app, you must accept the request previously sent. Roles supported on the Valuekeep Technician CMMS app: Root - Administrator Technician - Technician WorkManager - Work Manager
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background. To synchronize the data, you must ...
