How to configure mobile extensibility in the backoffice?
It is
possible to configure mobile extensibility. However, it should be noted that:
Extensibility
is available in the Universe plan;
Extensibility
only applies to custom attributes in the work orders;
Attributes
cannot be edited in the Mobile App;
Only the
following types of attributes are allowed:
- ShortText
- Text
- LongText
- Memo
- Phone
- URL
- Email
- Boolean
- Number
- Decimal
- Percentage
- Date
- DateTime
- Entity
Search
To configure the mobile extensibility, follow these steps:
- Go to Settings | General |
Companies;
- Create a company or select an existing one;
- Click on the + icon and activate the Settings extension;
- Select the Enable Custom Attributes option:
- Click on Save.
How to create mobile reports?
To create a mobile report, select the Definitions | Printing | Mobile Reports; The list of mobile reports is presented; Press the "Create" button. The report creation screen is presented; When creating the mobile report must consider the following ...
How do I configure the mandatory fields?
Configuring mandatory fields is a useful feature for controlling what kind of information is filled in and required whenever you create a device, location or route. Fields always have an attribute type associated: List: Attributes where there must be ...
How to configure the work order workflow?
The state flow for work orders can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Work | Workflow The state list is presented; To create new states, ...
How to configure the request workflow?
The state flow for requests can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Requests | Workflow The state list is presented; To create new states, ...
How do I see the list of geolocations?
It is possible to check all work and employee geolocation history. The geolocation list allows the maintenance manager to check the location history. To see the list, on the menu select the option "Workshops and Employees | Explore | Geolocations". ...
