Mobile - How do I create, edit or delete failures?
The failures are always associated to work orders. You can access the failure report using the Menu | Report Work
- On the Work order list, select the work order failure you wish to view to see;
- On the work order options (3 dots icon) click on Failures
- The list of failures report associated to the work order:
- Synchronized reports;
- Reports pending synchronization;
- Reports with a synchronization error.
Create Failures report
To create a failure report, access the failure reports list:
- Click on the (+) icon
- On the part failures report form, fill in the mandatory fields, identified with a (*)
- Click on the checkmark to save the report.
To report failures, you must consider that:
- It is only possible to create reports if the work order state allows to report work;
- It is only possible to record failures for work order assets or for the work order route and its descendants.
Edit Failure reports
To edit a Failure report, access the failure reports list:
- Click on the failure report you wish to edit;
- On the failure report form, edit the desired fields;
Changing the asset removes the recorded typifications.
Delete Failure reports
To delete a Failure report, access the failure reports list:
- Click on the failure report you wish to delete;
- On the failure report form, click on the trash icon to delete the failure.
It is not possible to delete synchronized reports.
Failure typification
The failure typifications are not mandatory and follow these rules:
- If the asset has a family and the family has defined typifications, only they are valid for that asset;
- You cannot record duplicated typifications.
Mobile - How to report/change or delete misc costs?
To report misc costs, you must perform these steps: Access Menu | Report Work; On the work order select the work order you wish to view/record the misc costs; On the work order options (3 dot icon) click on Misc Costs; A misc costs report list is ...
How to create custom mobile reports?
If you wish to create a custom mobile report, you must use our base report. Click the attachment to download the base mobile report.
Mobile - How to record/change/delete requisitions?
Table of contents To create a Requisition, follow these steps: 1. Access the "Requisitions" option; 2. The requisition list is presented: 1. Synchronized reports - these only allow to view, you cannot change them; 2. New reports ...
Mobile Requests - How to view and track follow-ups?
To access the Request follow-ups, follow these steps: 1. Access Menu | Requests 2. On the request list, select the request for which you wish to view the follow-ups; 3. Access the Follow-up tab on the lower part of the screen. 4. On ...
Mobile Requests - Error handling
On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
