Mobile - How do I create a Work Order?
The Work Order (WO) is the entity which represents the maintenance work to be performed for an asset or location.
To create a work order, follow these steps:
- On the menu, select the option "New Work Order";
- The work order creation window is displayed;
- Fill in the required fields (marked with a "*");
- Press the checkmark icon presented on the upper right field to save the report;
When creating the work order, the user must consider the following rules:
- The work order is in state Draft when it is not synchronized to the BO, when it is synchronized, it is created on the initial state defined on the BO.
- Only assets and locations specified in the authenticated user's access levels and workshops are displayed.
Did you know that you can filter the Asset lists?
To streamline the Asset selection process, these lists can be filters according to the user's needs.
When accessing an assets list (location, equipment or tool), on the upper right field, you can press the icon
which will open a new menu for the selection of the parameters being filtered. Later, and every time you access these lists, the selected filters will be saved and applied by default every time you access these lists.
For a user to be able to create work orders, they need to be configured as an employee and manager in the workshops.
Mobile - How to view the attachments for the work order and their assets
To view the attachments of a work order, you must enter the desired work order and press the attachment tab on the lower corner. The attachments will be presented in 2 areas: Work Order - Attachments regarding the work order; Assets - Asset ...
Mobile - How do I see the Work Order information?
To see information on a work order (WO), you have to go to the WO's list, select the desired WO and click on the information icon in the top right-hand corner. The information displayed relates to the selected WO, where the corresponding information ...
Mobile - How to explore work orders?
It is very important for technicians to be able to quickly view the work that they must perform. You can check the work that needs to be done through the following options: Technician dashboard – allows technicians to immediately know the number of ...
Mobile - How do I create, edit or delete failures?
The failures are always associated to work orders. You can access the failure report using the Menu | Report Work On the Work order list, select the work order failure you wish to view to see; On the work order options (3 dots icon) click on Failures ...
Mobile - How do I print a work order report?
The technicians can print the work order report with or without the signature when ending or during the execution. To print a work order report, it is necessary to access the detail window of the workorder. The access to this detail is performed ...
