Minimum operating system versions
To assure high performance levels and data security, minimum operating system versions have been implemented for the use of the Valuekeep Requester and Valuekeep Technician mobile applications:
  1. Windows: OS: 10 (Windows 10)
  2. Android: Android version 7 or higher
  3. iOS: iOS version 14 or higher
The two mobile applications do not support the Windows 11 version.
Please note that apps can only be installed via the Play Store, App Store or Microsoft Store.
The hardware of the device affects the performance of the APP.
    • Mobile Requests - How to associate an attachment to a request?
      To associate an attachment to a request, follow these steps: ​ i.On the screen for editing or creating a Request, press the "Attachments" tab" ii.On the top right corner, press the "+" symbol. A window with the "Photo" or "Files" options will be ...
    • Mobile - How to change the user on the Valuekeep CMMS app?
      The operating system where Valuekeep CMMS was downloaded can only be shared by more than one user. If several users use the same device to access Valuekeep CMS, every time they need to access Valuekeep CMMS, they will need to change users. To change ...
    • Mobile - How to see down time associated to a work order?
      When a work order is in a stopped operating state, the system automatically records a down time for the asset or location associated to the work order. To change WO downtime reports, access the work orders list (Menu | Report Work) On the work orders ...
    • Request Mobile - How to set up Valuekeep Requests?
      The Valuekeep Request configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
    • Mobile Requests - How to set up Valuekeep requests?
      The Valuekeep Request configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: i.Base configurations i.Language – by default, the app uses the ...
