How can the maintenance manager view the information of an asset associated with the work order?
A request is associated to an asset, this asset can be a location, equipment, tool or route. The maintenance manager has the chance to view the asset information using the request.
For the maintenance manager to view the request asset information, select the option "Work | Request Management";
1. The request list is presented;
2. Select the request you wish to view;
3. The request visualization window is presented;
4. Press the symbol
; 5. The dashboard with the information regarding the request is presented, select the dashboard with the name "Asset Information".
How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
How to report misc costs associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
How to view the traceability of a work order?
A work order can be originated from: I.Another work order; II.An order; III.A preventive maintenance event. To consult the traceability of a work order, select the option "Work | Work Orders". The list of work orders will be displayed; Select the ...
How to view the traceability of the work order?
It is possible to view the entity originated in a work order. The work order traceability list allows the maintenance manager to view if the work order originated in a request or in a preventive maintenance event, or if it was created individually. ...
