How do I insert monitoring values?
The Valuekeep monitorings can be fed information from individual records or through batch records by importing .csv files. To insert a new monitoring reading select the option Assets | Meters and Monitorings | Monitorings:
- A monitoring list is presented;
- Press the button Operations (down) to access the monitoring values list;
- After opening a monitoring values list, press the button "create";
Fill in the monitoring values data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
How do I create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
How can I see the list of monitoring values?
The list of monitoring values allows the maintenance manager to view globally all the values for all monitorings, whether they are from work orders or not. To view the menu list, select the option Assets | Explore | Monitoring Values or search ...
How do I insert meters values?
The meters can be loaded through individual records, in batch or by importing .csv files. Meter values can be introduced in two ways: Value Increase: Difference between the current reading and the previous reading. It is used in Increment-type meters ...
How can I create monitorings?
The monitorings are system entities which allow for monitoring the normal operation of the assets by monitoring a preset value and, depending on its positive or negative variation, trigger corrective maintenance actions. To create a new monitoring, ...
How to report monitoring values associated with the work order?
Every time the Work Order state is configured to allow recording work, it will be possible to associate monitoring readings to the work order, if the work order asset has associated monitoring. To record monitoring readings for the Work Order select ...
