How do I insert meters values?
Valuekeep meters can be fed information from individual records or through batch records by importing .csv files. To insert a new meter reading, select the option Assets | Meters and Monitorings | Meters:
- A meter list is presented;
- Press the button Operations (down) to access the meter values list;
- After opening a meter values list, press the button "create";
The meter values can be inserted in two ways:
- Increment Value – Difference between the current value and the previous reading, which is used in Increment meters;
- Meter Reading - Current meter reading, which is used in Reading meters.
When inserting meter values, you must consider the following rules:
- The inserted value in the Increment Value or in the Meter Reading can never be superior to the Maximum Value placed on the meter.
- The Meter Reading will be automatically restarted when the Maximum Value is reached.
- You cannot record readings for the same meter and asset.
- When a meter value is deleted, all values for the same meter with a date after the value that was eliminated will be updated to ensure conformity. The cumulative reading and the average will be recalculated.
Fill in the meter values data. The information to be filled in is organized in tabs. You can see the required fields using the orange margin or from the list on the right lower corner, next to the Reset button;
How do I insert monitoring values?
The Valuekeep monitorings can be fed information from individual records or through batch records by importing .csv files. To insert a new monitoring reading select the option Assets | Meters and Monitorings | Monitorings: A monitoring list is ...
How do I create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
How can I create monitorings?
The monitorings are system entities which allow for monitoring the normal operation of the assets by monitoring a preset value and, depending on its positive or negative variation, trigger corrective maintenance actions. To create a new monitoring, ...
How can I see the list of monitoring values?
The list of monitoring values allows the maintenance manager to view globally all the values for all monitorings, whether they are from work orders or not. To view the menu list, select the option Assets | Explore | Monitoring Values or search ...
How to create assets?
