The
tasks can be inserted from individual records or through batch records by
importing .csv files.
To load
batch assets, select the option Definitions| General | File Import:
- The import screen
is displayed;
- Select the option
Import Tasks;
- Download the
template file to be loaded, on the upper part of the screen and fill in
the file;
- Later, you must
fill in the file according to the rules:
- The fields
TaskKey, and Description must be defined.
- If the column
TaskKey is not filled in, the row will be ignored.
- The links of the
files on the columns Attachment1, Attachment2…Attachment10 must be added.
Each record has a limit of 10 attachments, and if that value is updated,
the attachments are not added. For example: the task already has 4
attachments, only 6 more attachments will be added, even if the file
contains 10.
- If the file is
reimported, the task attachments will be added. Regardless of already
having been added in another import.
- The attachments
must be stored on the Dropbox, on GoogleDrive or on another storage
service that provides a direct download link.
- The task image
When
filling in the file, you must consider the following fields:
- The file
must always be of the CSV type and the separator character must be ;
(semicolon);
- Each file
cannot have more than 2000 records or 4 Mb.
You
must not remove or add columns to the downloaded template.
How to import maintenance plans?
The maintenance plans can be introduced using individual records or by using batch records, by importing .csv files. To batch load maintenance plans select the option "Definitions| General | File Import": The import screen is presented; Select the ...
How I do remove tasks?
To delete tasks in batches, select the option Definitions| General | File Import: The import screen is presented; Select the option Delete Tasks; Download the template file to be loaded, on the upper part of the screen and fill in the file; Then, ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
How do I import parts entry?
The parts entries in stock can be fed from individual records or through batch records by importing .csv files. To load batch parts entries, select the option Definitions | General | File Import or using the parts entries list ( Parts and Inventory | ...
How to import spare parts?
The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
