How do I import parts entry?
The
parts entries in stock can be fed from individual records or through batch records
by importing .csv files.
To load
batch parts entries, select the option Definitions | General | File Import or using the parts entries list ( Parts and Inventory | Explore | Parts
Entries ) by selecting the option Import Parts Entries.
- The import screen
is displayed;
- Download the
template file to be loaded, on the upper part of the screen and fill in
the file;
- Later, you must
fill in the file according to the rules:
- The fields
DocumentType, Description, Date, Warehouse, Part, Quantity and Unit must
be defined.
- If there is more
than one row for the same warehouse, the fields are defined based on the
first row of the file.
- If the file has
more than one row for the same warehouse, to add parts entries, simply
define the warehouse and the part information.
- If the column
Warehouse is not filled in, the row will be ignored.
- When the import
is finished, the import date will be presented, and it might (or not)
contain messages with import details. If an import occurs without
errors/warnings, no information on the import details will be presented.
If there are errors/warnings on the import, you can see the errors by
clicking on the number of messages.
- The upload is
performed by Warehouse and as a transaction. That is, all records
regarding the Warehouse must be inserted successfully, otherwise, no
record for that Warehouse is recorded.
- After filling in
the file, load it on the section "Select file to be imported";
- Press the
"Import" button;
When
filling in the file, you must consider the following fields:
- The file
must always be of the CSV type and the separator character must be “;
”(semicolon);
- Check if
all values have zeros on the left and that they are kept. Some editing
softwares can remove the zeros;
- The
decimal values must be separated by “.” (dot).
Each
file cannot have more than 1000 records.
The field ‘Company’ must be filled in if there is more than
one Company. To check the company you wish to use, view the company
identifier, on the product, on the lateral left bar.
Please
check if the Part exists on the mentioned Warehouse, before importing the file.
How to import spare parts?
The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
How can I delete parts?
To delete batch parts, select the option Definitions| General | File Import: The import screen is displayed; Select the option Delete Parts; Download the template file to be loaded, on the upper part of the screen and fill in the file; Later, you ...
How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to view the existent parts stock in each warehouse. To view the list, select the option "Parts and Inventory | Explore | Parts Stock" or search "Parts Stock". The Parts Stock list has the ...
How do I import tasks?
The tasks can be inserted from individual records or through batch records by importing .csv files. To load batch assets, select the option Definitions| General | File Import: The import screen is displayed; Select the option Import Tasks; Download ...
