How to view the work orders?
The
administrator has a list where it is possible to view all his work orders.
To
view the list, on the menu select the option Work |
Work Orders.
The
list has the following criteria:
- It is
only available for the administrator role.
- The list
is ordered in decreasing order of work order date.
- From the
list, you can access the work order view screen.
- You have
the following filters available:
- Date: work
order date;
- Expected
date: expected work order date;
- States:
states the work orders are on;
- WO
types: work order types;
- Assets:
work order equipment, tools, locations and routes;
- Workshops:
work order workshop;
- Priority
levels: work order priority levels;
- It is
possible to have more search options on the list using the search box and
by selecting the field to be searched on the 3 dots.
How to view the traceability of a work order?
A work order can be originated from: I.Another work order; II.An order; III.A preventive maintenance event. To consult the traceability of a work order, select the option "Work | Work Orders". The list of work orders will be displayed; Select the ...
How to view the state transitions for a work order?
A work order is created in the initial state and until it is finished, it goes through different states. The technician and the maintenance manager can view all states the work order went through. To view the work order states, select the option ...
How to view the traceability of the work order?
It is possible to view the entity originated in a work order. The work order traceability list allows the maintenance manager to view if the work order originated in a request or in a preventive maintenance event, or if it was created individually. ...
How to view the employees assigned to the work order?
For a technician to execute the work orders on Valuekeep Mobile it is necessary that they are assigned to them. The list of assignments allows the maintenance manager to view the work orders assigned, as well as the technician(s) assigned. To view ...
How can I see my work orders?
The Technician has a list, where you can see all of his assigned Work Orders To see the list on the menu select the option "Work| My WOs". The list follows these criteria: It is only available for the administrator role. The presented list is in ...
