How to view the verified tasks associated to a work order by employee?
The work
orders might contain maintenance plans tasks or additional tasks that require
verification. The
task verifications' list (detail) allows the maintenance manager to view the
task verification by employee in each work order by maintenance and task plan.
To
view the menu list, select the option "Work | Explore Work
| Task Verifications (Detail)" or search "Task Verifications
(Detail)".
The task
verification list (detail) has the following criteria:
- It is
only available for the administrator role.
- By
default, only the work orders whose start date is on the current quarter
are presented.
- The
list is ordered in decreasing order of work order date.
- Only
the work orders with tasks that need verification are presented.
- It is
possible to search the list using the search box and by selecting the
field to be searched on the 3 dots.
The
task verifications can be performed using the work order record.
How to create a work order?
How to view the work orders?
The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work | Work Orders. The list has the following criteria: It is only available for the administrator role. The list is ...
How to view the employees assigned to the work order?
For a technician to execute the work orders on Valuekeep Mobile it is necessary that they are assigned to them. The list of assignments allows the maintenance manager to view the work orders assigned, as well as the technician(s) assigned. To view ...
How to add tasks to the work order?
After creating a work order, it is possible to add new tasks. To add a Task to a work order, you must access the work order file and open the tab "Additional Work": The list of additional tasks associated to the work order is presented On the list, ...
How can I verify the progress of the task verifications associated with a work order?
The work orders might contain maintenance plans tasks or additional tasks that require verification. The task verification list allows the maintenance manager to view the task verification progress for each work order. To view the menu list, select ...
