How to view the traceability of a work order?
A work order can be originated from:
I.Another work order;
II.An order;
III.A preventive maintenance event.
To consult the traceability of a work order, select the option
"Work | Work Orders".
- The
list of work orders will be displayed;
- Select
the work order you wish to view
- A
work order view window is displayed;
- Press
the context panel (symbol
); - The
dashboards with the information regarding the work order are presented,
with the name "Traceability".
If
the work order is independent (does not depend on another, or on a request or
preventive maintenance), it will not have traceability.
How to view the traceability of the work order?
It is possible to view the entity originated in a work order. The work order traceability list allows the maintenance manager to view if the work order originated in a request or in a preventive maintenance event, or if it was created individually. ...
How to view the work orders?
The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work | Work Orders. The list has the following criteria: It is only available for the administrator role. The list is ...
How to view the state transitions for a work order?
A work order is created in the initial state and until it is finished, it goes through different states. The technician and the maintenance manager can view all states the work order went through. To view the work order states, select the option ...
How to view the employees assigned to the work order?
For a technician to execute the work orders on Valuekeep Mobile it is necessary that they are assigned to them. The list of assignments allows the maintenance manager to view the work orders assigned, as well as the technician(s) assigned. To view ...
How to view the verified tasks associated to a work order by employee?
The work orders might contain maintenance plans tasks or additional tasks that require verification. The task verifications' list (detail) allows the maintenance manager to view the task verification by employee in each work order by maintenance and ...
