How to view the state transitions of a contract?
A contract is created in the initial state and until it is
finished, it goes through different states. The administrator has the chance to
view all the states the contract went through.
For the administrator to view the contract states, select the
option "Contracts | Contracts".
- The
contract list is presented;
- Select
the contract you wish to view;
- The
contract visualization window is presented;
- Press
the symbol
- The
dashboard with the information regarding the contract is presented, select
the dashboard with the name "Transitions".
How to set up the contract workflow?
The state flow for contracts can be changed to be in line with the organization's working method. To create or change the configurations for a new state, you must access Settings | Contracts | Workflow; 1. The state list is presented; 2. To create ...
What is the default contract workflow?
By default, the contract workflow has the following states: State Notes New Initial state. Approved Canceled Final state. Closed Final state. The following scheme shows how to process transitions between states:
How to view the list of contract types?
The Contract Types list allows you to view all contract types. To view Contract Types list on the menu, select the option Settings | Contracts | Contract Types or search "Contract Types". The Contract Types list has the following criteria: It is only ...
How to view the state transitions for a work order?
A work order is created in the initial state and until it is finished, it goes through different states. The technician and the maintenance manager can view all states the work order went through. To view the work order states, select the option ...
How to view the state transitions of a request?
A request is created in the initial state and until it is finished, it goes through different states. The requester or the maintenance manager has the chance to view all the states the request went through. For the requester to view the request ...
