How to view the requisitions workflow?
You can change the flow of states for requests to ensure that they match the organization's way of working.
To create or change the settings for a status, follow these steps:
- Access Settings |
Requisitions | Workflow;
- Click on Create or select an existing status;
- Fill in the required fields;
- In the Entity field, select the REQUISITIONS.REQUISITIONS option if you want to create or configure request statuses;
- In the Requisition extension, activate the Allow Cost Entry option if you want cost entry in the current state;
- Activate the option Allow Create Stock Receipt if you want to create a stock receipt;
- Click on Save and New.
When creating or editing statuses, you should take the following into account:
- There must be a start and end state for each entity;
- By default, entities are created in the state defined as initial.
- The final state defines the end of the entity's state flow, as it cannot have transitions to other states.
- To fill in the other languages in the description, you must edit the state with a user who has the language configured in their profile.
- Maintenance configuration for Request states.
By default, the options Allow Cost Report and Allow Create Stock Receipt are active and in Approved status. However, you can change this.
How do I create requisitions?
Using the requisitions, the employees in an organization can request parts to maintenance. To create a requisition, follow these steps: Go to Requisitions | Requisitions; Click on Create; Fill in the necessary fields. Click on Save and New. ...
How to set up the contract workflow?
The state flow for contracts can be changed to be in line with the organization's working method. To create or change the configurations for a new state, you must access Settings | Contracts | Workflow; 1. The state list is presented; 2. To create ...
What is the default contract workflow?
By default, the contract workflow has the following states: State Notes New Initial state. Approved Canceled Final state. Closed Final state. The following scheme shows how to process transitions between states:
How to create requisitions using a work order?
It is possible to create and manage requisitions through a work order. The work order must be in a state that allows creation requisitions. To create a requisition from a work order you must: Access the work order list Select the work order for which ...
How to view preventive parts?
The list of preventive parts allows you to have an overview of the task parts for the preventive plans and the corresponding quantities needed for consumption. To view the list the menu select the option Work | Explore Work | Expected Prev. Maint. ...
