How to view the parts from one supplier?
You can view the parts by accessing a
supplier file and selecting Operations-Parts (lower right corner, next to
Edit).
A Parts list filtered by the selected
Supplier will be presented.
To view the Supplier Parts list, select the
option Overview | Suppliers and Customers | Suppliers | Desired Supplier |
Operations | Parts.
The list has the following criteria:
- It is only available for the administrator role.
- Only the parts for the selected supplier are presented.
How to view preventive parts?
The list of preventive parts allows you to have an overview of the task parts for the preventive plans and the corresponding quantities needed for consumption. To view the list the menu select the option Work | Explore Work | Expected Prev. Maint. ...
How to view spare parts by asset?
The spare parts list allows to have an overview of the pieces used, where they are used and the quantities needed. To view the list, on the menu select the option Assets | Explore | Spare Parts or search Spare Parts. The spare parts list has the ...
How do I consult the parts/warehouses list?
Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to view the existent parts stock in each warehouse. To view the list, select the option "Parts and Inventory | Explore | Parts Stock" or search "Parts Stock". The Parts Stock list has the ...
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
