How to view the list of misc costs?
It is possible to check all misc cost records
associated to a work order. The misc costs list allows the maintenance manager
to check all misc cost records associated to a work order.
To view a misc costs list on the menu, select the
option "Work | Explore Costs | Misc Costs" or search
"Misc Costs".
The misc costs list has the following criteria:
- It is
only available for the administrator role.
- By
default, only the misc costs of the current quarter.
- The
list is ordered in decreasing order of work order expected date.
- From
the list it is possible to access the work order view screen.
- It is
possible to search the list using the search box and by selecting the field
to be searched on the 3 dots.
Misc
costs can be recorded using work orders
How do I consult the Miscellaneous Costs list?
The maintenance manager can check all the miscellaneous cost records associated with a work order. You can access this list under Work | Explore Costs | Miscellaneous Costs or by searching for Miscellaneous Costs in the search available in the ...
How to report misc costs associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record misc costs. To record misc costs you must access the work order file you wish to record the costs "Work | Work Orders", select the WO you wish to record the cost. ...
How to view the work orders?
The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work | Work Orders. The list has the following criteria: It is only available for the administrator role. The list is ...
How to create a work order?
How to view the list of total costs?
It is possible to check all costs associated to a work order. The total costs list allows the maintenance manager to check all costs associated to a work order. The list includes the costs in the company configuration currenct and the costs in the ...
