How can I see the list of consumptions?
It is
possible to check all consumption records associated to a work order. The
consumptions list allows the maintenance manager to check all consumption
To view
a consumptions list on the menu, select the option "Work | Explore
Costs | Consumptions" or search "Consumptions".
The
consumptions list has the following criteria:
- It is only
available for the administrator role.
- By default, only
the consumptions of the current quarter.
- The list is
ordered in decreasing order of work order expected date.
- From the list it
is possible to access the work order view screen.
- It is possible to
search the list using the search box and by selecting the field to be
searched on the 3 dots.
Consumptions
can be recorded using work orders.
How do I report consumptions using a requisition associated with the work order?
When a work order (WO) is in a state that allows to record costs, it is possible to record material consumption. However, before registering, you should note that: it is only possible to register consumptions if the WO status allows cost ...
How to report consumptions associated with the work order?
When a work order is in a state that allows to record costs, it is possible to record material consumptions. To report material consumptions, you must access the work order file you wish to report the costs to "Work | Work Orders ", select the WO ...
How can I see my work orders?
The Technician has a list, where you can see all of his assigned Work Orders To see the list on the menu select the option "Work| My WOs". The list follows these criteria: It is only available for the administrator role. The presented list is in ...
How to create a work order?
How to see the list of failures?
From the Work Order it is possible to record asset failures. The failure list allows the maintenance manager to see asset failures by work order. To see the menu list select the option "Work | Explore | Failures". The failure list follows these ...
