How to view spare parts by asset?
The spare parts list allows to have an
overview of the pieces used, where they are used and the quantities needed.
To view the list, on the menu select the
option Assets | Explore | Spare Parts or search Spare Parts.
The spare parts list has the following
criteria:
- Allows to filter by asset, parts or records where the total
stock quantity is inferior to the total needed quantity.
- The cell Total Stock is presented in red when the total stock
- The list is ordered by asset key, in increasing order.
How to import spare parts?
The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
How to use spare parts?
In an equipment, tool or location, you can associate spare parts. To associate them, follow these steps: Access the Menu in the option "Assets" - "Location" / "Equipment" / "Tools" Edit or create "Location" / "Equipment" / "Tools" On the Spare Parts ...
How to view preventive parts?
The list of preventive parts allows you to have an overview of the task parts for the preventive plans and the corresponding quantities needed for consumption. To view the list the menu select the option Work | Explore Work | Expected Prev. Maint. ...
How to batch delete spare parts?
To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
