How to view the traceability of the work order?
It is possible to view
the entity originated in a work order. The work order traceability list allows
the maintenance manager to view if the work order originated in a request or in
a preventive maintenance event, or if it was created individually.
To view
the work order traceability list on the menu, select the option "Work
| Explore Work | Work Order Traceability" or search "Work
Order Traceability".
The
traceability list has the following criteria:
- It is only
available for the administrator role.
- By default, only
the work orders whose start date is on the current quarter are presented.
- The list is
ordered in decreasing order of expected date.
- From the list it
is possible to access the view screen for the work order, event,
preventive maintenance and request.
- It is possible to
search the list using the search box and by selecting the field to be
searched on the 3 dots.
A work
order can have several requests associated, but only one request can have an
associated work order.
How to view the traceability of a work order?
A work order can be originated from: I.Another work order; II.An order; III.A preventive maintenance event. To consult the traceability of a work order, select the option "Work | Work Orders". The list of work orders will be displayed; Select the ...
How to view the work orders?
The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work | Work Orders. The list has the following criteria: It is only available for the administrator role. The list is ...
How to view the state transitions for a work order?
A work order is created in the initial state and until it is finished, it goes through different states. The technician and the maintenance manager can view all states the work order went through. To view the work order states, select the option ...
How to view the employees assigned to the work order?
For a technician to execute the work orders on Valuekeep Mobile it is necessary that they are assigned to them. The list of assignments allows the maintenance manager to view the work orders assigned, as well as the technician(s) assigned. To view ...
How to view the verified tasks associated to a work order by employee?
The work orders might contain maintenance plans tasks or additional tasks that require verification. The task verifications' list (detail) allows the maintenance manager to view the task verification by employee in each work order by maintenance and ...
