How to view preventive labor?
The preventive labor list allows you to have an overview of the employees and their specialties of the preventive plans tasks, as well as the corresponding planned and reported times.
To consult the list in the menu, select the Work | Explore Work | Expected Prev. Maint. Labor or search Expected Prev. Maint. Labor.
The preventive labor list has the following criteria:
i.Allows you to filter by preventive maintenance, workshop or time interval for the expected date;
ii.The Expected Date, Reported Time cell is displayed in red when the reported time is greater than the planned time;
iii.The list is sorted by expected date, in ascending order.
    • How to view preventive parts?
      The list of preventive parts allows you to have an overview of the task parts for the preventive plans and the corresponding quantities needed for consumption. To view the list the menu select the option Work | Explore Work | Expected Prev. Maint. ...
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • How do I consult the Labor List?
      Through the Labor list, the maintenance manager can verify all the associated labor logs. To consult the Labor list, simply go to Work | Explore Costs | Labor or search for Labor. This list is only available for the Administrator and Work Manager ...
    • How to create a new version of the preventive maintenance?
      Creating new versions allows you to improve preventive maintenance by reusing the current configuration. To create a version, access Work | Preventive Maintenances; The list of preventive maintenances will be displayed; Select the preventive ...
    • How to batch create work orders using preventive maintenance events?
      Managing preventive maintenance events allows you to create Work Orders for each preventive maintenance event. To do so, follow these steps: Go to Work | Preventive Maintenance | Prev. Events Management; Filter the data by Preventive Maintenance, ...
