How to subscribe to Valuekeep Integrator?
The use
of the Valuekeep Integrator platform requires a subscription to the addon with
the same name.
The subscription
request should be requested to your partner developer.
What is Valuekeep Integrator?
Valuekeep Integrator recommends a conceptual model of data integration and consequent functional logic between systems. As a solution for integration between systems, Valuekeep Integrator brings together a set of characteristics which are considered ...
How to set up the Valuekeep Integrator?
The Valuekeep Integrator can be installed using the following options: · Portal (link): download the Valuekeep Integrator addon setup available and install it; · PRIMAVERA Deployment Center: this option is only available for customers that subscribed ...
How does the Valuekeep Integrator work?
Valuekeep Integrator is a generic and abstract platform to implement any data or system integration scenario (across different technologies). The abstraction is represented by the concept of pipeline and consists of the decomposition of a complex ...
What is the Valuekeep-Integrator architecture?
The VALUEKEEP V3 - Valuekeep Integrator plugin, provides in its installation folder: <Install Path> <VKKPlugin\SAMPLES\CONFIGS, an integration solution (VK3_V10_Integration.config), that can be reused as a base example, which can be customized ...
What is the Valuekeep Integrator-SDK?
Valuekeep Integrator - SDK provides a Security wizard (available in the installation folder) that provides cryptographic services, including secure encryption and decryption of data, which allows encryption of keys, namely passwords that must be ...
