How to set up the Valuekeep Integrator?
The Valuekeep Integrator can be installed using the following options:
·        Portal (link): download the Valuekeep Integrator addon setup available and install it;
·        PRIMAVERA Deployment Center: this option is only available for customers that subscribed to the VK.INT – Valuekeep Integrator module (PRIMAVERA Licensing). If this requirement is met, you must (recommended practice) configure it and install it in the PRIMAVERA Deployment Center, according to the configuration/installation procedures for this service.
The Valuekeep Integrator configuration is performed using the Integration.Config, that contains the access data and the complete definition for the Pipelines execution context.
Several Integration templates are available in your installation folder: <Install Path>\VKPlugin\SAMPLES\.
More configurations on the structure for file integration.Config.
Watch this example video to learn how to configure the Valuekeep Integrator with ERP - Primavera v10.
    • What is Valuekeep Integrator?
      Valuekeep Integrator recommends a conceptual model of data integration and consequent functional logic between systems. As a solution for integration between systems, Valuekeep Integrator brings together a set of characteristics which are considered ...
    • How to set up Valuekeep Integrator?
      ​ Watch this video and learn how to set up VK Integrator.
    • How does the Valuekeep Integrator work?
      Valuekeep Integrator is a generic and abstract platform to implement any data or system integration scenario (across different technologies). The abstraction is represented by the concept of pipeline and consists of the decomposition of a complex ...
    • What is the Valuekeep-Integrator architecture?
      The VALUEKEEP V3 - Valuekeep Integrator plugin, provides in its installation folder: <Install Path> <VKKPlugin\SAMPLES\CONFIGS, an integration solution (VK3_V10_Integration.config), that can be reused as a base example, which can be customized ...
    • How to subscribe to Valuekeep Integrator?
      The use of the Valuekeep Integrator platform requires a subscription to the addon with the same name. The subscription request should be requested to your partner developer.
