How to set up the pipeline execution (Windows Service)?
The host is the
process runtime than instantiates the Valuekeep Integrator engine
(PipelineEngine) to manage the pipeline execution (using a scheduling
procedure or using a specific on-demand context).
The platform
provides a Windows Service available at: <InstallPath>\VKPlugin\TOOLS.
However, you can use other hosting services, such as: Windows
App, Web App, Azure App, etc.
Conceptually,
when a host starts up (for example, Windows Service), it creates an
execution context from the existing configuration file(s). Later, for each
active pipeline with an associated scheduler, it creates a worker to
periodically execute the pipeline in this execution context. Internally,
the worker creates a pipeline execution engine instance
(PipelineEngine) and give it the context.
WebApi - Auditing Pipeline
The Valuekeep Integrator conceptually allows to monitor the execution of all pipelines. This feature allows the implementing agent/integrator to control the execution of integration flows and identify irregular situations that require to eventually ...
Webapi - How to create a part of the service type?
This method allows to create a part of the service type in a simplified manner. The method to be used to create a part of the service type is: POST url/api/mytenant/myorganization/businesscore/parts Json example to create a part of the service type: ...
How to customize the pipeline tags for the request URL?
In Valuekeep, there are "POST" requests, which come from keys, as shown below: The method used to create a follow-up report in a work order is: POST ...
What is a Pipeline?
A Pipeline is a sequence of activities that are executed in a flow (workflow). Conceptually, Valuekeep Integrator is a generic and abstract platform that allows implementing any scenario of data or system integration (in different technologies). The ...
Example of a custom pipeline configuration
The Valuekeep pipelines can be customized and configured based on the business model being implemented. Next, we show an example as a webinar:
