How to set up the Mappers (Structure)?
The syntax and semantics applied in data
transformation is defined in a modeling context and easy to interpret, using a
format or protocol (JSON - JavaScript Object Notation) of data representation,
based on the JavaScript programming language, which allows defining a
standardized transformation structure.
Thus, the syntax applied in the data
transformation process obeys the rules and principles defined in the JSON
language format, namely: data types, properties, objects, arrays, etc..
In semantic terms, we adopted a structure that
can be reused in any plugin, in order to satisfy the exchange of data between
different systems. This semantic structuring is based on the following
conceptual model:
- Table: identification (name)
of the object or array in the JSON structure of the target system;
- Fields: definition of the
structure of an object or array (for example, the composition of the attributes
of a given entity);
- Field: identification (name)
of the property to which the transformed value will be assigned (for example,
the name of an attribute of a particular entity);
- Handlers: specification
(properties) to be applied in data mapping and transformation (assignment of
the transformed value as a function of the mapping applied).
How to set up the Mappers?
can be used to implement integration services. The data transformation procedure is defined in the pipeline configuration, where you can identify/configure this service. The plugin provides a GenericMapper mapping service, which can be applied in the ...
Plugin V10 – Pipelines – Mappers
A service integration solution must be able to easily define data bidirectional transformations, from their native representation to other formats, more adequate for the process integration, such as: XML, JSON. The PRIMAVERA V10 – Valuekeep ...
How to set up the Mappers (Expression Values)?
In addition to the set of properties that can be applied to data transformation models, the GenericMapper transformation service provides a methodology (ExpressionValues) that allows you to apply to a given property an expression whose degree of ...
Hot to set up the Mappers (Property Sets)?
The following table lists properties (tags) that can be applied to data transformation models. Property Description Example DefaultValue Allows you to express a default value. PipelineVariable Allows you to express a defined value in the pipeline ...
How to set up the Mappers (Property Sets)?
A tabela seguinte enumera propriedades (tags) que podem ser aplicadas nos modelos de transformação de dados. Propriedade Descrição Exemplo DefaultValue Allows you to express a default value. PipelineVariable Allows you to express a defined value in ...
