How to set up the Mappers (Property Sets)?
A tabela seguinte enumera propriedades (tags) que podem ser aplicadas nos modelos de transformação de dados.
Propriedade | Descrição | Exemplo |
DefaultValue | Allows you to express a
default value.
PipelineVariable | Allows you to express a defined value in the pipeline context.
The following
variables are available: @FROM_TYPE; @TO_TYPE; @FROM_COMPANY;
@TO_COMPANY.
EnvironmentVariable | Allows you to express a defined value in the context of the
integration solution.
The following
variables are available: @FROM_TENANT; @TO_TENANT; @FROM_ORGANIZATION;
@TO_ORGANIZATION; @FROM_USER; @TO_USER; @SYSTEM_DATE.
IgnoreOnUpdate | Allows you to specify that
the transformation is ignored in case of update. |
IsUserField | Allows you to specify that
the attribute is a user field. | |
IsEnumerable | Allows you to specify that
it is a detail (an array). | |
TableKey | Allows you to specify the
key of the detail (array) | |
Hot to set up the Mappers (Property Sets)?
The following table lists properties (tags) that can be applied to data transformation models. Property Description Example DefaultValue Allows you to express a default value. PipelineVariable Allows you to express a defined value in the pipeline ...
How to set up the Mappers (Expression Values)?
In addition to the set of properties that can be applied to data transformation models, the GenericMapper transformation service provides a methodology (ExpressionValues) that allows you to apply to a given property an expression whose degree of ...
How to set up the Mappers?
can be used to implement integration services. The data transformation procedure is defined in the pipeline configuration, where you can identify/configure this service. The plugin provides a GenericMapper mapping service, which can be applied in the ...
How to set up the Mappers (Structure)?
The syntax and semantics applied in data transformation is defined in a modeling context and easy to interpret, using a format or protocol (JSON - JavaScript Object Notation) of data representation, based on the JavaScript programming language, which ...
Plugin V10 – Pipelines – Mappers
A service integration solution must be able to easily define data bidirectional transformations, from their native representation to other formats, more adequate for the process integration, such as: XML, JSON. The PRIMAVERA V10 – Valuekeep ...
