How to set up the Mappers?
can be used to implement integration services.
The data transformation procedure is defined in the pipeline configuration, where you can identify/configure this service. The plugin provides a GenericMapper mapping service, which can be applied in the integration solution. The following screenshot exemplifies the use of the mapping service.
The syntax and semantics applied are defined in a modeling context that is easy to interpret, as you can see in the following example.
The plugin distributes several example mapping files in: <InstallPath>VKPlugin\SAMPLES\MAPPERS\, which you can explore and use in developing your pipelines.
    • Plugin V10 – Pipelines – Mappers
      A service integration solution must be able to easily define data bidirectional transformations, from their native representation to other formats, more adequate for the process integration, such as: XML, JSON. The PRIMAVERA V10 – Valuekeep ...
    • How to set up the Mappers (Expression Values)?
      In addition to the set of properties that can be applied to data transformation models, the GenericMapper transformation service provides a methodology (ExpressionValues) that allows you to apply to a given property an expression whose degree of ...
    • How to set up the Mappers (Structure)?
      The syntax and semantics applied in data transformation is defined in a modeling context and easy to interpret, using a format or protocol (JSON - JavaScript Object Notation) of data representation, based on the JavaScript programming language, which ...
    • Hot to set up the Mappers (Property Sets)?
      The following table lists properties (tags) that can be applied to data transformation models. Property Description Example DefaultValue Allows you to express a default value. PipelineVariable Allows you to express a defined value in the pipeline ...
    • How to set up the Mappers (Property Sets)?
      A tabela seguinte enumera propriedades (tags) que podem ser aplicadas nos modelos de transformação de dados. Propriedade Descrição Exemplo DefaultValue Allows you to express a default value. PipelineVariable Allows you to express a defined value in ...
