How to set the preventive maintenance's time zone?
Preventive Maintenance allows you to set the time zone in which events must occur. This way you can locally setup events that must occur on the day and at the time of the place where the work will be performed.
The event preview displays events that use the date and time of the selected time zone. After being approved, the recalculation of events will always be done using this time zone.
If necessary, you can change the time zone of a preventive maintenance by creating a new version.
    • How to set the calendar and time schedule in a preventive maintenance?
      When creating a preventive maintenance on the "Scheduling" tab, it is possible to define a Calendar and a Time Schedule. When defining a Calendar, it is possible to select between the following options: i.None; ii.Default company; iii.Other: If this ...
    • How does preventive maintenance rescheduling work?
      The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • How to set the preventive maintenance plan replacement?
      On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following: None main (Multiplier) Replacement The plan replacement rules are the following: All maintenance ...
    • What is preventive maintenances batch management?
      Preventive maintenances management was designed to allow you to simultaneously change the state, delete or create new versions for a set of preventive maintenances. For that, you must access Work | Preventive Maintenance | Preventive Maintenance ...
