How to set the preventive maintenance plan replacement?
On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following:
- None
- main (Multiplier)
- Replacement
The plan replacement rules are the following:
- All maintenance plans with a main replacement criteria must have at least an associated replacement maintenance plan.
- A main maintenance plan cannot be associated to another main maintenance plan.
- A maintenance plan must have a main plan associated.
- The replacement plans cannot have a recurrence defined.
- The several replacement plans for the main plan must have a different number of events.
- The number of events, on a replacement plan, must be higher than 0.
Examples
- Maintenance by recurrence with replacement plan, multiplier criterion:
Preventive maintenance created on 07/04/2020, with the following maintenance plans.
Maintenance plan
| Recurrence
| Main Plan
| Event
PM0001
| Every month, on the 27th at 09:00
PM0003
| PM0001
| 3
PM00012
| PM0001
| 12
Event
| Maintenance Plan
| Expected Date
1
| PM0001
| 27/04/2020 09:00
2
| PM0001
| 27/05/2020 09:00
3
| PM0003
| 27/06/2020 09:00
4
| PM0001
| 27/07/2020 09:00
5
| PM0001
| 27/08/2020 09:00
6
| PM0003
| 27/09/2020 09:00
7
| PM0001
| 27/10/2020 09:00
8
| PM0001
| 27/11/2020 09:00
9
| PM0003
| 27/12/2020 09:00
10
| PM0001
| 27/01/2021 09:00
11
| PM0001
| 27/02/2021 09:00
12
| PM0012
| 27/03/2021 09:00
As this scenario shows, every 3 events (3, 6, 9, …) it is replaced by the plan PM00003 and every 12 by the PM00012 (12, 24, 48, …)
- Maintenance by recurrence with replacement plan, multiplier criterion and initial event:
Preventive maintenance created on 22/4/2020, with the following maintenance plans:
Maintenance Plan
| Recurrence
| Main Plan
| Events
| Starts at
PM00001
| 2
PM00006
| PM00001
| 6 | 2
Event | Maintenance Plan | Expected Date |
1 | PM00001 | 27/04/2020 09:00 |
2 | PM00006 | 27/05/2020 09:00 |
3 | PM00001 | 27/06/2020 09:00
4 | PM00001 | 27/07/2020 09:00
5 | PM00001 | 27/08/2020 09:00
6 | PM00001 | 27/09/2020 09:00
7 | PM00001 | 27/10/2020 09:00
8 | PM00006 | 27/11/2020 09:00 |
9 | PM00001 | 27/12/2020 09:00 |
10 | PM00001 | 27/01/2021 09:00
11 | PM00001 | 27/02/2021 09:00
12 | PM00001 | 27/03/2021 09:00
In this case, the first replacement occurrence will occur on Monday, not Friday. That is to say, replacements are advanced compared to the normal plan.
How to plan the preventive maintenance for several years?
The events are not all generated when the preventive maintenance is approved. The events are rescheduled daily according to a set of rules. The following rules: Events based on the recurrence: If the preventive has a daily plan, a maximum of 2 years ...
How to define a maintenance plan tolerance in a preventive maintenance?
When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances: AdvanceTolerance DelayTolerance The tolerance considers the following logic: AdvanceTolerance: ...
How to create a preventive maintenance?
Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
How to join plans on the preventive maintenance?
When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
How to set the preventive maintenance's time zone?
Preventive Maintenance allows you to set the time zone in which events must occur. This way you can locally setup events that must occur on the day and at the time of the place where the work will be performed. The event preview displays events that ...
