How to set the calendar and time schedule in a preventive maintenance?
When creating a preventive maintenance on the
"Scheduling" tab, it is possible to define a Calendar and a Time
Schedule.
When defining a Calendar, it is possible to
select between the following options:
i.None;
ii.Default company;
iii.Other: If this option is selected, a "Work
Calendar" option is available where it is possible to select a Calendar
and associate it with preventive maintenance.
When defining a Time Schedule, it is possible
to select between the following options:
i.None;
ii.Default company;
Time Schedule" option is available where it is possible to select a Time Schedule
How to set the preventive maintenance's time zone?
Preventive Maintenance allows you to set the time zone in which events must occur. This way you can locally setup events that must occur on the day and at the time of the place where the work will be performed. The event preview displays events that ...
How does preventive maintenance rescheduling work?
The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
How to create a preventive maintenance?
Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
How to set the preventive maintenance plan replacement?
On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following: None main (Multiplier) Replacement The plan replacement rules are the following: All maintenance ...
What is preventive maintenances batch management?
Preventive maintenances management was designed to allow you to simultaneously change the state, delete or create new versions for a set of preventive maintenances. For that, you must access Work | Preventive Maintenance | Preventive Maintenance ...
