How to set a preventive maintenance with fixed date?
On the Work Orders tab, you can set the scheduling criteria to set the event on a fixed date, when applying this configuration, the events will always be created on the set date. This criterion is not influenced by the previous work order dates, that is, they always occur on the same date.
For example, if we define the event on the first Monday of each month, it must always be on that set day.
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • How to set the preventive maintenance plan replacement?
      On the maintenance plans of a preventive maintenance, it is possible to select the replacement criteria. The replacement criteria can be the following: None main (Multiplier) Replacement The plan replacement rules are the following: All maintenance ...
    • How to plan the preventive maintenance for several years?
      The events are not all generated when the preventive maintenance is approved. The events are rescheduled daily according to a set of rules. The following rules: Events based on the recurrence:  If the preventive has a daily plan, a maximum of 2 years ...
    • Calculating Preventive Maintenance events with counters and Opening or Closure scheduling criteria
      The cumulative reading value of a preventive maintenance event becomes the same as the last counter reading when: the Work Order has an associated preventive event; the event is the last one with an associated Work Order (most recent); the preventive ...
    • How to set the preventive maintenance's time zone?
      Preventive Maintenance allows you to set the time zone in which events must occur. This way you can locally setup events that must occur on the day and at the time of the place where the work will be performed. The event preview displays events that ...
