How to see the list of parts issue?
To view the list, select the option "Parts and Inventory | Explore | Parts Issue".
The parts issue list follows these criteria:
- It is only available for the administrator role.
- By default, only the parts issue whose expected date is on the current quarter will be presented.
- From the list it is possible to access the warehouse view screen.
How to report/delete a stock parts issue?
The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
How to record a stock parts entry?
The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
How do I see the list of parts entries?
The parts entry list allows the administrator to view the parts entry. To view the list, select the option "Parts and Inventory | Explore | Parts Entry". The parts entry list follows these criteria: It is only available for the administrator role. ...
How do I create parts?
Items can be used in the maintenance plans for forecasting needs and/or in the material consumption report after being created. To create an item, select the option Parts and Inventory | Parts: The parts list is presented Press the button "create" ...
How do I consult the parts/warehouses list?
Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
