How can I see the list of monitoring values?
The list
of monitoring values allows the maintenance manager to view globally all the
values for all monitorings, whether they are from work orders or not.
To view
the menu list, select the option Assets | Explore
| Monitoring Values or search Monitoring Values.
The monitoring
values list has the following criteria:
- It is
only available for the administrator role.
- By
default, only the inactivations whose start date is on the current quarter
are presented.
- The
list is ordered in decreasing order of value date.
- It is
possible to search the list using the search box and by selecting the
field to be searched on the 3 dots.
The
value records can be performed using the monitoring record or the work order.
How do I insert monitoring values?
The Valuekeep monitorings can be fed information from individual records or through batch records by importing .csv files. To insert a new monitoring reading select the option Assets | Meters and Monitorings | Monitorings: A monitoring list is ...
How do I insert meters values?
Valuekeep meters can be fed information from individual records or through batch records by importing .csv files. To insert a new meter reading, select the option Assets | Meters and Monitorings | Meters: A meter list is presented; Press the button ...
How do I create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
How can I create monitorings?
The monitorings are system entities which allow for monitoring the normal operation of the assets by monitoring a preset value and, depending on its positive or negative variation, trigger corrective maintenance actions. To create a new monitoring, ...
How do I inactivate assets?
This operation makes it easier to inactivate a set of assets and corresponding child assets. To access this option on the equipment or tool view screen, select the option Deactivation History. There are 3 asset inactivation modes: Dispose (this ...
