How to see the list of meter readings?
The meter reading list allows the maintenance manager to view the readings of all meters, whether they are from work order or not.
To view the list, on the menu select the option "Assets | Explore | Meter Readings" or search by "Meter Readings".
The meter reading list follows these criteria:
- It is only available for the administrator role
- By default, only the readings whose expected date is on the current quarter are presented
- The presented list is in decreasing order of reading expected date
- It is possible to search the list using the search box and by selecting the field to be searched on the 3 dots
The readings can be performed using the meter record or the work order.
How do I use the Assets Explorer?
The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
How do I load batch meter readings?
The meter values can be fed information from individual records or through batch records by importing .csv files. To load batch meter reading, select the option Definitions | General | File Importation or using the meter reading list (Assets | Meters ...
How do I create assets?
The creation of Assets is a critical step for the configuration of the system. These are the assets which will be subject to maintenance. To create an equipment/tool, select the option Assets | Equipment or Assets | Tool: The list of equipment or ...
How do I inactivate assets?
This operation makes it easier to inactivate a set of assets and corresponding child assets. To access this option on the equipment or tool view screen, select the option Deactivation History. There are 3 asset inactivation modes: Dispose (this ...
How to see the list of inactivations?
The inactivations list allows the administrator to view the inactivations history. To view the list, select the option "Assets | Explore | Inactivations". The inactivations list follows these criteria: It is only available for the administrator ...
