How can I see the list of location changes?
The location changes list allows the administrator to view the asset location changes.
To view the list, select the option "Assets | Explore | Location Changes".
The location changes list follows these criteria:
  1. It is only available for the administrator role.
  2. By default, only the location changes whose expected start date is on the current quarter will be presented.
  3. From the list it is possible to access the asset view screen.
    • How do I use the Assets Explorer?
      The asset explorer allows you to get an overview of the asset, avoiding having to consult several lists. As well as displaying descriptive information, by selecting the asset in the explorer you will also have access to the work information created ...
    • How do I inactivate assets?
      This operation makes it easier to inactivate a set of assets and corresponding child assets. To access this option on the equipment or tool view screen, select the option Deactivation History. There are 3 asset inactivation modes: Dispose (this ...
    • How do I change an asset's location?
      To change the location of an asset in batch, select the option in Assets | Equipment or Assets | Tool: The equipment or tools list is presented; Select from the list the equipment or tool that you wish to change the location; Press the ...
    • How do I record parent location change on the locations?
      To record a parent location change in a location, select the option Assets | Locations. The list of locations is presented Select the location you wish to record the Parent location change to and press the button "View" On the "Operations" link, ...
    • How can I see the list of parent device changes?
      With the profile of Administrator, you can see the list of parent device changes of the assets. This list is available at Assets | Explore | Parent Device Changes with the following specifics: Only available for the Administrator. From the list, you ...
